SwerveMonkey
Heya Goblineers! as others have mentioned in other threads, the winter/maintenance season is upon is in most of the states.
I'm a typical forum lurker, mostly just to see what new and clever solutions people come up with... But I need some guidance from the group as to what should be on the wish list of maintenance items for someone in my predicament.
#197 has had its season on the roads and ran fine with little to no problems...
occasionally she had a rough start after sitting for a week or two and not being turned over, figured that might be normal for something like this car.
but otherwise it is running great. the ODO has around 160K of so and I think that I want to tackle a timing chain replacement... even if it isn't warranted.
I know I definitely need to do an oil change, plugs & coils, and to top off coolant.
To get to the "ask"...
What helpful tasks should be done while doing a timing chain?
Do I really need to change the Cam Gears at the same time?
I'd like to swap the clutch at the same time, is a light weight flywheel bad for such a light car?
What's been a good clutch that balances between performance and durability?
I'm still doing a lot of research on my end but wanted to put out the plea for help in the meantime, ha ha.
