Vwsaabvt
I'm at the end of the new wiring video 4- organizing the main harness part 1.
At the end of the video around 7:40 it says:
1. there should be a group of wires that need to be extended- I have those
2. Two wires that will be used for the fuel pump- shouldn't there be 3? I have purple, tan, and grey
3. A pink wire for the coolant level- Isn't the coolant level wire pulled to the other end towards the bcm plug? Is the pink wire in the video for the intercooler pump for turbo models?
4. Twisted pair of tan data wires- I kept the pair from the ebcm to fuse block. There was also another pair that went ebcm to body-dash connector I'm assuming those dont matter.
5. Loose blue and green wires, I have these
But I also have a pink wire and blue wire tied together and I dont remember why
I'm guessing the picture is the body to engine harness connector, I have an 06 ss.
