Hi everyone, I have been searching the forums for advice on this, and found quite a bit, unfortunately none of it has panned out for me yet. Here is the situation:
Donor was an 09 LS cobalt, automatic
Goblin is an A/T version
I have everything assembled minus the seats and the tail lights, and the darn thing won't crank when you turn the key. I can get it to crank just fine by jumping the relay in the fuse box with a paper clip, but with the key turn nothing much happens (a bunch of clicks and little whirrs behind me as relays go and I think the fuel pump primes). I have taken the fuse box apart twice to check for bent pins and or improperly seated multiplugs and found nothing there, and all the multiplugs are cranked down tight. I've checked the grounds all over the place and everything is good with an ohm meter. I've checked to make sure there is a ground coming out of the white multiplug in the fuse box, and there is and it is seated on the frame. I've checked for voltage from the battery at the starter, that is good (verified by screwdriver jump on the posts, and again with a paper clip in the relay). I've swapped relays with no success there either. I have double checked that the brake position sensor is connected, which it is, and checked for continuity through it to the battery, 2 of the three wires show small resistance to the black post on the battery and the middle one reads as an open line, I have done the same to the shifter connector, with the black wire there showing good connection to a ground lug. I'm pretty stumped! Anyone have any ideas for other things to check? The only lights that are on are a check engine light and the air bag light, and after a couple minutes with the key on the tire pressure light comes on (I do not have the tire pressure fob thing connected), I do have one plug that isn't connected to anything under the dash area, I'll include a couple pictures of it as I have no idea where it is supposed to go.
Please help!
Thanks!
Please help!
Thanks!
