Goblinfanclub1234
- Goblinfanclub1234 Goblin Guru
the smaller coolant most likely goes to the overflow tank
One bolt is not enough. The passenger side engine mount is incorrect, it is far too long. You should have one the looks like this one. Here's the PN.
View attachment 39539View attachment 39540
I have the same problem (frame #466). The guy they have bending lines is making them an inch too long for some reason. I think I'm going to try to "zig zag" the line down the tunnel to take up the extra length. How did you end up fixing yours - did you keep it as pictured?Another update. We got the steering rack on, complete with new tie rod ends. Then we put the brake lines in and ran into a problem. The line ended up being about 1" too long. Did we get shipped a wrong size line?
We "fixed" the problem by putting the brake line under the square frame bar rather than in front of it. I believe we got the end of the line to the right position in the end, but will this placement interfere with anything else being put on the front? Will the line be out of place when we go to attach to it later?
View attachment 39163View attachment 39164View attachment 39165
I got confused by a lot of that too. Here's what I did for the passenger side:Okay. Got the mount and installed it. That taken care of.
Now I am trying to finish the coolant lines and gas lines.
The packaging only lists 1 1.25 coupler. The videos show us using two. There are also not enough clamps for a second coupler. Have they changed how the coolant hoses attach? We are one coupler and two clamps short of finishing that out.
Also, how do I connect the fuel lines. The video says there was a fuel hose that came in the stage 1 box but we do not have one. Am I missing something here? I have some extra length of that plastic hosing used for the brake booster. But the gas line adapters do not fit that.
Working towards that first start, but the gremlins keep popping up.
It's a bit early to be fearmongering like that considering the post-pop issues are more system-wide than not getting the fuel pump to come on.Did you jumper the fuel pump relay at any point? If so, it's possible the fuse box has a bad circuit that is now open.
If I recall correctly, my power (and standard routing) goes from the battery to the starter, from the alternator to the starter, and from the rear fuse box to the starter. If you can probe 12v from the alternator positive to ground and from the fuse box hot to ground (with the key off, right?), then you should have continuity from the battery to the starter.there is definitely power going to the rear. The power hits the alternator and then goes to the fuse box.
To my knowledge, the low coolant switch in the overflow tank will not cause a no-start. I ran without it hooked up for a while.a couple of thoughts, we filled the coolant from the over flow. Took nearly two gallons. Is it necessary to put some coolant in the passenger side hose at the engine like in the video? Would the engine sense a lack of coolant and not start?
Passkey issues can be weird. I'm far from an expert on the system on an LSJ and I can't say whether your car is the same. If Passkey is the reason for your no start, I think it'll do everything but turn over, so that doesn't sound like your issue.there was a light that kept flashing on the display when we took the key out. It was a lock and key? Is there an anti theft issue? This was a 2005 with manual windows so I doubt it, but maybe?
You can bridge the positive lead from the battery to the signal post which should just have a single small purple wire on it and the starter should engage and spin. The starter is case grounded so you can check resistance from the body to the negative post on the fuse box but you'd have a hard time introducing any meaningful resistance there with anything you could've reasonably done.with all of the items operating, I don’t think we have a grounding issue, but maybe? Maybe the starter is not grounded? Anyway to test just the starter?
