Be aware: the actual T/O bearing feed pipe(7) is not a spiral pig's tail thinggie like this diagram shows! It is just about 6" of pipe with some purposeful but simple bends and very specific ends on it. (Actually rather boring looking.) Rock Auto has an actual pic. I guess bored artists show up in odd places like service manuals and parts lists. This is truly "an Artist's Mis-Conception". Nice drawing though!
I have had this bookmarked just in case, hopefully it helps a bit.Ok so I got a borescope in there and the slave cylinder isn't holding pressure. It is what's leaking so I'm pulling the transmission and replacing all those parts.
I heard there's a way to pull the transmission without pulling the engine completely. Is that true?
Any input is welcome
Is it easy to pull the housing off and check the second gear syncro/block ring in the transmission?
Make sure the elbow is tight. I had an issue where mine had come loose and caused a leak. It's two pieces, not one solid part. It was a pain to tighten in the vehicle. See the photo below:What else should I replace while in there? So far I got a new slave, tube and elbow. Looks like there may be a seal in there as well? Sorry I've never done anything like this before
Awesome!... how do I do that? Feeler gauges? And what's the toleranceYou also need to check the throwout bearing clearance.
yes. see DM.I heard there's a way to pull the transmission without pulling the engine completely. Is that true?
Video here. ZZP calls it the "air gap" and they sell a spacer if it's too much.
Throw Out Bearing Spacer – ZZPerformance
It's hard to say exactly since it will depend on how much extension will be available on a particular brand of throw-out bearing before it overextends and leaks.I measured out at 3/16", just a hair over with a .250 blue spacer from zzp. According to the video, I *should be fine.
Not trying to hijack a thread, but its sort of relevant if we're talking about it.
