V1 Clutch Pedal
You need to save everything from the master cylinder back. the entire pedal box is used as is. I don't remember anything in particular about removing it though.
The clutch master cylinder does a quarter turn or less counter clockwise if I’m not mistaken and then slides out. But you have to disconnect it from the back of the pedal first. Then it’s 2-3 nuts to the firewall and then the assembly comes off.
