I ordered those same rubber Dorman 905-508 Control Arm Bushing mounts before I found the Moog K201285 Control Arm Bushing.
Wish I would have known about the Moog parts earlier... much better than the rubber ones.
Why use tape instead of rivets and silicone?
Lonny has found some urathane-type adhesive they are trying to replace the silicone. It's much like the window urathane.
What is used to remove it if need be? Sounds like serious tape!
Windshield urethane is some tough ****. The only way to break the seal is cut it and scrape it off with a sharp knife. Watch a glass guy some time they have short stroke sawsall's with a knife blade on the end. I would stick with vhb tape and or silicone.Lonny has found some urathane-type adhesive they are trying to replace the silicone. It's much like the window urathane.
Connector 1
Which wiring harness and where on the harness. Take a shot of the whole harness showing about where it is located.
Connector 2
If it is part of your body harness and it's near the fuse box connectors it may connect to your engine harness. If so it's a keeper.
Connector 3
That may be a speaker wire.
Connector 4
I believe that is your CHMSL (3rd brake light).
The light blue wire should attach to one of the fuse box connectors.
Connector 1
Connector 2
Connector 3
Connector 4
Yes to bothDumb question, does the kit come with an air filter or an intake tube?
