V1 Diagram for brake booster vacuum sensor (LNF)?
AZmoto
AZmoto
It looks like I have to wire the brake booster vacuum sensor into my harness. The only thing I came up with on Alldata was the pinout for the connector. Does anyone have a diagram showing where these go?
DCMoney
It's been a while since I used all data but can you search the circuit numbers and it give you any results.
If not you may have to look at the BCM, ECM, and/ or fuse block diagrams and look for the matching circuit numbers.
ColoradoCryptoTrader
do you know what problems this can cause by not having it connected?
I have a 2008 LNF and right now I have the sensor mounted on the booster but it is not connected to anything. I am having trouble with my boost pressure sensor not working, maybe these things are related?!?
