V1 .DWG file for the button panels??
ColoradoCryptoTrader
finished dash ready to drop in. it *should* fit in there perfectly. I brushed the aluminum to save cost for now.
I anticipate using my horn a lot LMAO.
29514
29515
I think you're going to end up moving that horn. When you're all strapped in, you're not going to be able to reach that (easily), unless you're a sasquatch.
Looks great though!!
That's about where my horn is, but I don't know when the last time I used a horn in any of my vehicles. I just stuck it on before I had it registered in case I had to do an equipment/safety inspection to get it registered.
If I have to redo this after some road testing that is cool, this should be a good starting point. The intercooler inlet and outlet temp gauges are probably a waste of effort, but I am going to do some testing and see how well the rear mount intercooler works.
let the record show that there is plenty of room to shift all of the gears with this panel. I also have the threaded shift knob screwed directly into the shift lever. have to change the gauges to F still. horn is also easy to reach while sitting back.
32951
OptimizePrime
Steering wheel lookin' BEEFY. This project turned out looking noice.
You going to use oil pressure in the open slot?
Thanks for the link on the button plates those look great!
I think down the road I'll switch to an external oil cooler and add oil pressure gauge. Future upgrades!
also the angle of the picture is misleading, there is a ton of space between the wheel and the dash.
