Stretch2126
- Stretch2126 Well-Known Member
So I have an interesting problem that seems to persist. I’ve replaced the slave cylinder and the small clutch pipe before this just for a heads up.
My clutch will work one day, then give up the next morning. My fix is disconnect the block, put it back on in the sequence, then bleed it. Then it’s good as new. It was worse with an aftermarket block so I put the stock one back on.
Today I moved the car around and it was fine. Two hours later it’s soft and assume it’s leaking into the bell housing. Just took the block off and put it back on, bled it twice and good as new.
I’m curious to see if I need a THIRD clutch block or if the aftermarket seal caused issues cause I think I changed it all back to stock.
And I know someone will ask, yes I checked that I didn’t have two seals lol.
