- Rauq Goblin Guru
At the risk of saying something you've already been told or heard previously, the seal between the elbow and the clutch pipe has to be installed on the top of the clutch pipe before the clutch elbow is installed on the top of the clutch pipe. If you put the two pieces together and then pull them back apart, there's a decent chance the seal will stay inside the elbow. It is not likely to seal again that way, so you have to pull it out of the elbow and reinstall on top of the clutch pipe. This post from an HHR forum shows the seal stuck inside the elbow. The thread doesn't make resolution clear but I'm pretty sure that was their issue.
Additionally, as you'll have new parts in the mix, make absolutely certain there's only one seal present. Remember the seal likes to stay inside of and hide in the elbow.
