V1 Fenix's Goblin #461 - 2010 Base Auto
Fenix Nexen
waiting on replacement parts, its starting to get too cold. i went out for a ride the other day when it was nice out and i didnt have much fun at all. most likely going to be putting the kitcar away for the season and im not sure if ill bother fixing it anytime soon either. im heavily discouraged from cars at the moment with whats happened with this kitcar and then the other cobalt im trying to fix sucking up the money i have left and getting essentially no where.
Well this is one of the major tasks facing us Forum Posters. We are as much Tech Support as Cheering Section. Remember, you are taking on a task that the majority of car lovers wouldn't/couldn't touch with a 10' pole! And you are apparently working on two at once!, but apparently you like a challenge. All I can say is, the challenge(if carefully stored) will be there in the spring! It can be completed, as shown by many other posters. So fall back, regroup, and prepare for the next foray! Sometimes the best way through is rest and research. Bon Route! :cool:
Fenix Nexen
old headlights burnt out, connectors melted. put on new ones. night driving is much better now. still need to do repairs from when i stuck that hitch. need to clean up the garage too. roof, side curtains, and fenders still need done. stuck paying credit card debt for a long while so no idea when ill get around to it. the roof is so ugly. thats all the news i have for now i guess.
56670
Fenix Nexen
iv been dealing with a loud buzzing noise coming from the engine around 40 to 60 mph at around 2k rpm. any ideas? a quick search is pointing to a bad torque converter. the noise is as loud as the engine. im on a 4 speed automatic. how hard is it to replace it?
Engine noise or transmission noise? How have you tried to diagnose to determine it's the transmission versus an engine noise?
If your torque converter is going bad you should be experiencing inconsistent slippage or stuttering during acceleration and excessive heat buildup in the transmission. It may actually start feel like your engine has an abnormal increase in RPM before the transmission starts to move the car.
Turn up the radio. Problem solved. :cool:
Could be TC. Can you changed the noise with rpm or shifts? Or one foot steady on gas then tap the brake pedal to change Tcc input? Maybe an axle if it increases with speed only. ?
Joebob
Could be harmonics of something loose. Check the exhaust bolting and the collector gasket. Mine likes to blow out about once a year. Check that all the mounting bolting is tight too. If there are no drivability issues, it might be vibrating components like the license plate.
