The long axle on the passenger side will be the weak link. Using the LSJ/LNF setup with the jackshaft/axle on the passenger side will be stronger. Also, the LNF axles are larger diameter and inherently stronger than all other 'stock' axles - but these are almost impossible to find and are not manufactured any more. If you need bullet proof axles, custom ones with a warranty are the best way to go. Check ZZP to see what axles they carry, they did have some custom ones a while back.
