V1 Harness guide Part 10 2:50.
Dakota8800
Dakota8800
Slow and steady progress. The wiring harness a been a huge and tedious learning experience for me, but I think I secretly like it. The end is in sight!
In harness guide, Part 10 2:50, Lonny references a green wire with a white stripe and a pink wire (For older models such as mine) to add to the button panel wires. I think I found the wires, but they are on a connector I labeled 'cluster control'
Are these the correct wires? Should I just cut the connector in the picture and add it to the wires referenced?
2005 ss/sc
Thanks!
Those are your info and return button wires that control your gauge cluster.
You will need the pink and green with a white stripe.
Don't get the pink wire mixed up with the positive pink wire.
Dakota8800
Awesome, thanks! I'm a dummy and I forgot to label each pink wire. However, I will just trace them and refer to alldatadiy to find which is which.
