It’ll be both front brakes on one circuit and both rear brakes on the second circuit. If you want to add the optional proportioning valve it goes in the rear fluid circuit which is where I’ll be plumbing in the hydraulic park brake valveOne question I always had: does the goblin have 2 independent hydraulic systems for the break? Like front left and rear right together on one and front right and rear left on a separate one?
The proportioning valve should go on the front brake circuit so you can lessen the pressure to the front brakes as they will lock before the rears the way the system is balanced for the Cobalt. You actually lessen the front bite quite a bit to get the threshold braking where the fronts go just a bit before the rears.It’ll be both front brakes on one circuit and both rear brakes on the second circuit. If you want to add the optional proportioning valve it goes in the rear fluid circuit which is where I’ll be plumbing in the hydraulic park brake valve
Thanks for letting me know that. I haven’t gotten that far just yet. Years ago I had to put a proportioning valve in my mustang cause the rear brakes were locking up but I guess it is reversed in the GoblinThe proportioning valve should go on the front brake circuit so you can lessen the pressure to the front brakes as they will lock before the rears the way the system is balanced for the Cobalt. You actually lessen the front bite quite a bit to get the threshold braking where the fronts go just a bit before the rears.
