V1 Justin's city extended (09 ss/tc)
Justin
J
Hello everyone. I have had my kit for awhile now, I believe it's chassis #101. I think it's long overdue for me to start my build log. I kinda lost interest in the project for the last several months but work is starting to slow down for me and I now have some time to dedicate to the car and hope to have it on the street before the end of the year. I started my car for the first time today and just hearing it run is really motivating. Here is a list of the mods that I have done to the car so far.
-Ldk crate motor from zzp
-Wiseco pistons and zzp forged rods
-Opel fuel injectors
-South bend stage 4 clutch and new flywheel
- built f35 trainsmission with quaife lsd, cryo treated gear set and 4.45 final drive
-zzp zfr 6758 turbo
- derale heat exchanger
- And I changed the intake ( didn't really like the stock one)
Here are some pics of the progress I had made so far.
Wow, you are almost done. 2 seats, front hubs, 5 wheels (steering wheel).
You have a lot of nice parts. What did you do for an engine tune? (I am learning HP Tuners now)
J
I got a tune from zzp. It idles a little rough till it warms up, probably because I did not tell them what intake I have. But once it's on the road I'm going to take it in for a dyno tune
J
I'm trying to put on the rear solstice calipers on but I dont know what the torque specs for the 8 bolts that came in the kit, also it came with 4 washers, what bolts get the washers? Any help or pictures would be greatly appreciated
The numbers written beside the bolts is the torque specifications (in foot pounds).
I took some quick pics, the wheels were in the way, but hopefully they are of some use to you.
It is dirty - looks like someone recently dragged it out of a autocross ditch.
9849
9850
9851
9852
9853
9854
9855
9856
Washers generally prevent the steel nuts and bolts from digging into the aluminum parts. I don't think I used any of them as spacers.
Update: I see some washer spacers on one wheel cable - this was to balance the 2 cables where they join near the parking brake handle. You might not need these.
J
Thanks, I paid too much for it. I think it was close to $4,000. It's from a company in Oswego, IL called performance autowerks. I have heard of another company called B3 design on Facebook that I think might be cheaper
J
They are enkei pf01 evo 17x9.5 0 offset. With 275 tires. No spacers required, looks to have plenty of clearance front and rear.
J
I'm having a really hard time fitting the tunnel cap on. I measured the inside of the tunnel cap and the outside walls of the tunnel and there is a 7mm difference. I just don't see how this is going to fit. Anyone else have this problem with theres?
Yes. I used big channel lock pliers to pull the sides together.
It was kind of bumpy when I was done, but it is under the tunnel cap, and the cap is straight, so nobody but me knows. Oh dang.
J
Alright I will try that. I tried bending a large section with a piece of wood c-clamped to the side of the tunnel but it didn't work.
