Bigfoot Goblin
Keep in mind that the suspension setup needs to be made with an equivalent weight in the seat(s) that will be relatively the same as your normal driving load. If it is just you, then use your weight on the driver's side to get your camber and toe set properly. Not doing this will make one side more out of the optimum geometry once it is weighted and unbalance the suspension.
Chaning degrees into inches will depend upon the diameter of your tires. there was a chart on the web, but I can't find it again. Maybe try Dr. Google to see if you can locate it?
