V1 my Goblin is unwell
P
well balls. I ran the goblin two days in a row without any issues, just trying to get the coolant system fully burped out and functioning (the A/T version has the radiator in the back, my hose routing needs some work), and went to start it last night again to test the fans (they had not been working, so I re-wired them to the original fan connector), and the darn thing is back to no-crank. It does have a P0315 error code for the crankshaft position sensor not learned after the ECM swap, but it ran just fine with that code on there before. I charged the battery overnight and it is showing good, although I did notice that it has a .3 amp draw when the key is out, so something isn't right somewhere (that's not a surprise). I found a fuse that was burned out and replaced that, so the tail lights are working now, although the third brake light does not work yet. Does anyone know if that P0315 code can prevent it from cranking?
