V1 Nuker's City Goblin build - 2007 SS SC Donor - Completed/Licensed
Waterdriver
Does it have a reverse lockout?
I have a 2005 SS, lockout is like the 80's and earlier vette's.
Underneath the shift knob, on the shaft, pull up with your index and middle finger. Then shift into reverse.
I think reverse may be further over to the right than 5th. So you may need to adjust your left cable. I think it will need to be shortened.
Without the lockout you may have trouble finding 5th once you get reverse working.
I think your shifter's left to right position should be very close to vertical when in neutral.
TheNuker
Here is a copy of the invoice so that you can see the connectors that they used on the brake lines.
Nuker-
TheNuker
I think that I need to look at it more tonight, I ordered a short throw with 1" lower top part also since I find my hand hitting the gauge cluster haha.
Thanks,
Nuker-
Waterdriver
What offset is the rear wheels? I was wondering before ordering wheels myself.
Looks like you have some decent clearance between the tire and strut.
Your Goblin is looking good!
TheNuker
Thanks Alex!
A quick question, I think these are the right parts to replace the steering wheel. After getting in and out a few times I think the bit of extra room from a flat bottom will be helpful.
https://www.amazon.com/gp/product/B01MXE1SBD/ref=ox_sc_act_title_1?smid=A3VO4BNDPNR55F&psc=1
https://www.amazon.com/gp/product/B008FT5ZLW/ref=crt_ewc_img_dp_3?ie=UTF8&psc=1&smid=A3GMPUWM5FEUA5
Also I'm having a time with the dash buttons. Anyone recall which color wires go to what? I really just need to get the horn and hazard buttons going for inspection.
Thanks!
Nuker-
PG5
That's pretty much the setup I was planning. Except maybe doing the Leather instead of the suede. I know that's the right hub for the Cobalt so I imagine it should work for the Goblin.
Thanks Alex!
Thanks!
Nuker-
Ah I spent a lot of time trying to figure this out.
So that hub is used to adapt the shaft to either one of their quick releases OR a 6 bolt steering wheel.
And I wouldn't get it. The DF kit comes with a three bolt adapter already that is much smaller and cleaner. Simply get a three bolt to 6 bolt conversion plate off eBay. It's much cheaper.
http://m.ebay.com/itm/Car-0-5-1-2-H...3D262411806118&_trksid=p2056116.c100408.m2460
Or we can all ask really nicely and hope DF just machines the adapter with 6 bolt as an option.
TheNuker
Ughhhhhhhhh this wait tell inspection is killing me(earliest date was june 26th). I'm running out of roads to suit my driving style in my neighborhood.
Going to finish horn/flashers god willing tomorrow.
Nuker-
