Ben Eldridge-Peter
- Ben Eldridge-Peter Member
Rich I live absurdly close to you in salisbury nh. Im really interested in starting this project do you mind if I talk to you about it somtime?
There is a little ring that goes on the steering shaft that the blinker clicky hits and turns off after you turn.
I'll try to take a pic of it tonight.
Nuker-
Nuker-
I just put the snap ring on. I knew it was on the original shaft but I didn't see the groove for it. I had to tap the shaft back to finally expose it completely. I knew I wasn't going to get by without having to pull the steering wheel hub at least once. Luckily I had a harmonic balancer puller that worked great!
Mount it with the tab 180 degrees from the turn signal. If you consider the turn signal to be at 10:00 position, mount the tab (with the steering wheel centered) at 4:00. That way it cancels at the same for both left and right turns. The little piece works really well.Is this a DF provided item?
Question for anyone flat towing an automatic.
Do I need to do anything special?
I know Dan heavily modified his, but is any of that necessary?
