- Bretter Well-Known Member
Hopefully this is helpful for people! Original at: http://www.yourcobalt.com/forums/problems-service/19543-torque-specs-fluid-capacities.html
Approximate Fluid Capacities
The following approximate capacities are given in English and metric conversions. See Fluid and Lubricant Recommendations for more information. All capacities are approximate. When adding, be sure to fill to the approximate level, as recommended in this manual. Recheck fluid level after filling.
Cooling System
•2.0L L4 Engine Supercharged - RPO LSJ
5.7 liters
6.0 quarts
•2.2L L4 Engine - RPO L61
6.5 liters
6.8 quarts
•2.4L L4 Engine - RPO LE5
7.0 liters
7.4 quarts
Intercooler System 2.0L Engine - RPO LSJ
1.9 liters
2.0 quarts
Engine Oil With Filter
4.8 liters
5.0 quarts
6.0 liters
6.3 quarts
4.8 liters
5.0 quarts
Fuel Tank
51.1 liters
13.5 gallons
Transmission/Transaxle
•Transaxle, Automatic- Bottom Pan Removed 4T40-E
6.6 liters
7.0 quarts
•Dry
12.2 liters
12.9 quarts
•Complete Overhaul
9.0 liters
9.5 quarts
•Transaxle, Manual - Getrag 5 Speed
1.7 liters
1.8 quarts
•Transaxle, Manual - MU3
1.9 liters
2.0 quarts
Fastener Tightening Specifications
steering
power steering
Intermediate Steering Shaft Bolt
34 N·m
25 lb ft
Power Steering Assist Motor Bolt
19 N·m
14 lb ft
Rack and Pinion Outer Tie Rod End Nut
25 N·m + 90 degrees
18 lb ft + 90 degrees
Steering Gear Bolt
110 N·m
81 lb ft
steering wheel and column
34 N·m
25 lb ft
Steering Column Pivot Bolt
25 N·m
18 lb ft
Steering Column Mounting Bolt
25 N·m
18 lb ft
Steering Column Trim Cover Screw
2 N·m
18 lb in
Steering Column Jacket Bolt
11 N·m
97 lb in
Steering Wheel Nut
41 N·m
30 lb ft
front suspension
Ball Joint to Control Arm Nut and Bolts
70 N·m
52 lb ft
Ball Joint to Steering Knuckle Nut
•First Pass
50 N·m
Reverse Nut 3/4 turn
37 lb ft
•Second Pass
50 N·m + 30°
37 lb ft + 30°
Control Arm to Front Frame Bolts
55 N·m
41 lb ft
Control Arm to Rear Frame Bolts
100 N·m + 180°
74 lb ft + 180°
Frame to Chassis Bolts
100 N·m + 180°
74 lb ft + 180°
Intermediate Shaft Pinch Bolt
34 N·m
25 lb ft
25 N·m + 90°
18 lb ft + 90°
Stabilizer Link to Strut Nut
65 N·m
48 lb ft
Stabilizer Shaft Clamp Bolt
50 N·m
37 lb ft
Stabilizer Shaft Link to Stabilizer Bar Nut
80 N·m
59 lb ft
Strut Assembly to Steering Knuckle Nut
120 N·m
89 lb ft
Strut to Body Nut
20 N·m
15 lb ft
Strut Shaft Nut
70 N·m
52 lb ft
Transmission Mount Through Bolt
100 N·m
74 lb ft
Transmission Mount to Frame Bolt
50 N·m
37 lb ft
Wheel Bearing/Hub Assembly Mounting Bolts
115 N·m
85 lb ft
rear suspension
Bracket to Body Bolts
90 N·m + 45°
66 lb ft + 45°
Brake Hose Fittings
19 N·m
14 lb ft
Bushing Through Bolts
90 N·m + 60°
66 lb ft + 60°
Shock Bolt Lower
110 N·m
81 lb ft
Shock Bolt Upper
90 N·m
66 lb ft
Wheel Bearing/Hub Assembly Mounting Nuts
45 N·m + 30°
33 lb ft + 30°
wheels
Wheel Nuts
140 N·m
100 lb ft
axles
Intermediate Drive Shaft Bracket-to-Engine Block Bolts
50 N·m
37 lb ft
Wheel Drive Shaft Nut
210 N·m
155 lb ft
brakes
Accelerator Pedal and Sensor Assembly Mounting Bolts
9 N·m
80 lb in
Brake Hose-to-Brake Caliper Bolt
48 N·m
35 lb ft
Brake Master Cylinder Mounting Nuts
25 N·m
18 lb ft
Brake Pedal Bracket-to-Steering Column Bracket Bolt
25 N·m
18 lb ft
Brake Pipe Fitting at the Front Brake Hose
19 N·m
14 lb ft
Brake Pipe Fittings at the Master Cylinder
19 N·m
14 lb ft
Brake Pipe Fittings at the Proportioning Valve Assembly
19 N·m
14 lb ft
Brake Pipe Fittings at the Rear Brake Hose
19 N·m
14 lb ft
Front Brake Hose Bracket Retaining Bolt
25 N·m
18 lb ft
Proportioning Valve Assembly Bracket Mounting Bolt
25 N·m
18 lb ft
Vacuum Brake Booster Mounting Nuts
17 N·m
14 lb ft
Brake Caliper Bleeder Valve
11 N·m
97 lb in
Brake Caliper Guide Pin Bolt
34 N·m
25 lb ft
Brake Caliper Mounting Bracket Bolt
115 N·m
85 lb ft
48 N·m
35 lb ft
Brake Pipe Fitting at the Wheel Cylinder
19 N·m
14 lb ft
Wheel Cylinder Bleeder Valve
8 N·m
71 lb in
Wheel Cylinder Mounting Bolts
16 N·m
12 lb ft
Park Brake Cable Adjusting Nut, Drum Brakes
3.9 N·m
35 lb in
Park Brake Lever Assembly Mounting Nuts, Tighten in Sequence
25 N·m
18 lb ft
Park Brake Warning Lamp Switch Mounting Screw
3 N·m
27 lb in
Rear Park Brake Cable Guide Retaining Bolt
10 N·m
89 lb in
Brake Pipe Fittings at the Brake Pressure Modulator Valve (BPMV)
19 N·m
14 lb ft
Brake Pressure Modulator Valve Bracket Mounting Bolts
25 N·m
18 lb ft
Brake Pressure Modulator Valve-to-Bracket Mounting Bolt
5.6 N·m
50 lb in
Electronic Brake Control Module (EBCM) to Brake Pressure Modulator Valve (BPMV) Retaining Bolts
4.5 N·m
40 lb in
Engine Control Module Bracket Mounting Bolts
12 N·m
106 lb in
Cooling System
5.7 liters
6.0 quarts
6.5 liters
6.8 quarts
7.0 liters
7.4 quarts
1.9 liters
2.0 quarts
4.8 liters
5.0 quarts
6.0 liters
6.3 quarts
4.8 liters
5.0 quarts
Fuel Tank
51.1 liters
13.5 gallons
6.6 liters
7.0 quarts
•Dry
12.2 liters
12.9 quarts
•Complete Overhaul
9.0 liters
9.5 quarts
1.7 liters
1.8 quarts
1.9 liters
2.0 quarts
steering
power steering
34 N·m
25 lb ft
19 N·m
14 lb ft
25 N·m + 90 degrees
Steering Gear Bolt
110 N·m
81 lb ft
34 N·m
25 lb ft
25 N·m
18 lb ft
25 N·m
18 lb ft
2 N·m
18 lb in
11 N·m
97 lb in
Steering Wheel Nut
41 N·m
30 lb ft
front suspension
70 N·m
52 lb ft
•First Pass
50 N·m
37 lb ft
•Second Pass
50 N·m + 30°
37 lb ft + 30°
55 N·m
41 lb ft
100 N·m + 180°
74 lb ft + 180°
100 N·m + 180°
74 lb ft + 180°
34 N·m
25 lb ft
25 N·m + 90°
18 lb ft + 90°
65 N·m
48 lb ft
50 N·m
37 lb ft
80 N·m
59 lb ft
120 N·m
89 lb ft
Strut to Body Nut
20 N·m
15 lb ft
Strut Shaft Nut
70 N·m
52 lb ft
100 N·m
74 lb ft
50 N·m
37 lb ft
115 N·m
85 lb ft
rear suspension
90 N·m + 45°
66 lb ft + 45°
Brake Hose Fittings
19 N·m
14 lb ft
90 N·m + 60°
66 lb ft + 60°
Shock Bolt Lower
110 N·m
81 lb ft
Shock Bolt Upper
90 N·m
66 lb ft
45 N·m + 30°
33 lb ft + 30°
wheels
Wheel Nuts
140 N·m
100 lb ft
axles
50 N·m
37 lb ft
210 N·m
155 lb ft
brakes
9 N·m
80 lb in
48 N·m
35 lb ft
25 N·m
18 lb ft
25 N·m
18 lb ft
19 N·m
14 lb ft
19 N·m
14 lb ft
19 N·m
14 lb ft
19 N·m
14 lb ft
25 N·m
18 lb ft
25 N·m
18 lb ft
17 N·m
14 lb ft
11 N·m
97 lb in
34 N·m
25 lb ft
115 N·m
85 lb ft
48 N·m
35 lb ft
19 N·m
14 lb ft
8 N·m
71 lb in
16 N·m
12 lb ft
3.9 N·m
35 lb in
25 N·m
18 lb ft
3 N·m
27 lb in
10 N·m
89 lb in
19 N·m
14 lb ft
25 N·m
18 lb ft
5.6 N·m
50 lb in
4.5 N·m
40 lb in
12 N·m
106 lb in
