Ok,,,, soooooooooooo, I hooked the EPS Power wire up to 12 volts then with the key off, I checked resistance.... I have 120.6 Ohms across terminals 6 & 14 Indicating one of the computers has an issue. So I started disconnecting one plug at a time from the BCM . Each plug out , I checked the resistance. still 120.6 Ohms. now after each plug at the ECM. Still 120.6 Ohms. disconnected plug from ECM to engine harness. Still 120.6 Ohms. I completely removed the fuse box the ECM and the BCM. Still 120.6 Ohms. I unplugged the only other wire having to do with the network. the EPS . Of coarse it went to 0 Ohms that is where the data link goes to first.
