Sho do you have a build thread? If not you really should start one.
Does your gas gauge work correctly? Does the display in the dash display mileage and coolant temp etc?
I guess this can be my build thread...? lol I am basically almost done just diagnosing what is wrong with startup. I'll upload some pictures of what i have going on.
But yes gauge shows correct info like milage (shows same as cobalt before) gas gauge working correctly...
Just won't crank the starter at all. Starter cable coming from battery is connected directly to starter doubled with positive cable going to fuse box.
Seems like the conditions aren't being met because of some kind of safety relay or something like it. the transmission is mechanically in neutral position but is there something electrical looking at it?
also i mentioned above the yellow wire coming from clutch sensor...where is it going in fuse box? i may have cutting while thinning. please let me know! thanks
