Fenix Nexen
Can confirm that the four fuses after the run/crk relay becomes 12v when the key is switched on. The fuse labeled INJ is also getting 12v. This is good news I suppose?
Yes, good news. I am having difficulties on where to start on this issue too. Makes me want to go back to the OBDii codes.Can confirm that the four fuses after the run/crk relay becomes 12v when the key is switched on. The fuse labeled INJ is also getting 12v. This is good news I suppose?
All what share the same ground? The IAT sensor is grounded through the ECM.Do all those share the same ground on the engine block above the starter and below the intake manifold?
Some cobalt owners have grounded the case of the ECU and the TCU to the frame as a patch for the corroded engine block ground.
Not the best video, but what I am talking about. ECM is grounded through the plug to the block.All what share the same ground? The IAT sensor is grounded through the ECM.
Guess we will have to keep looking. The MAF reversal doesn't apply to your engine, and the electrical plug isn't it either.I grounded the TCU and ECU and nothing changed and the EXH fuse is getting 12v
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
You did find an electrical plug that wasn't plugged in! Clear the OBDii codes, and try starting it again? I'm not sure what that plug does, but it had to do something. Pull the OBDii codes again, and see if anything has changed.
Check for more missing plugs... that is what got my LSJ to start the first time... a missing plug on a sensor.
Not necessarily a problem, especially if your battery is a little weak.I just noticed that all the dials on the gauge drop and twitch downwards when the engine starts
I will get to work on some diagrams
I'm pretty sure they are turn signal wires (just went to my car and realized it was all taped up for "water proofing", so 90% confident).What do these plugs go to? The ingnition switch? I would make sure all plugs are installed as a lot of systems are related. (i.e cruise control tied to 3rd brake light circuit)
Looks like you are very close.
