You got it. The bar above the engine.Can you post a pic to show what you describing?
Is it the horizontal tube running between the strut towers?
I had a digital angle finder, which I put at each end and at the middle, and the ends were about 1.5 degrees off from the center.I'm not at home at the moment to verify, but I'm pretty sure that tube should be straight.
Did you lay a straight edge on that tube to verify what your seeing? With all the tubes around there, sometimes it can cause an optical illusion.
Not saying your not seeing it bowed, just hoping that it's not.
I had the same thought, I don't think it'll make too much of a difference. Unrelated, is that the stock turbo for your engine? The compressor outlet is different than mine. Also, it looks like you have a lot more clearance between the engine and the strut bar than I do.I went and looked at mine, it looks perfectly straight. I wouldn't think that it would throw off your subframe engine alignment though, even if it was just slightly curved
I did that yesterday. I didn't get a picture, but it was about 1/8" difference between ends and center. Again, though, I don't think it matters too much.I would say you need to use a straight edge. If the angle gauge was turned slightly it will read an angle.
I'm still not 100% sure. Like I mentioned above, it seems like the valve cover and frame are at the same angle, so if that is how it's supposed to be, then I guess it's right.On page 7 you mentioned having issues with the engine mounts and spacers. Are you sure everything is correct with that?
Yeah, I see that now, looking back at my pics. I just didn't remember there being a flange on the compressor outlet, had it in my head that it was one piece.It is the stock turbo, Borg Warner K04 I think is what it is. I have the adapter removed from the compressor side right now so that may be why it looks a little different. The angle makes it look like there is more room than there really is.
I hadn't talked to them about it, but they definitely seemed off. Like I said, I got the front one to work, though it could certainly have been easier, but the rear was nowhere close.I was talking to the guys at DF the other day, did you know that the solid mounts for the T/C SS were off and have to be re-fabbed? Mine don't fit either, not without a bit of persuasion ....okay, maybe alot
The package was just the new trans mounts, so I'll get those test-fitted.I've got a package arriving today from them, I'll wait and see what's in it first
