I had my frame powder coated at Kitsap Powdercoating in Poulsbo (closer to Kingston actually). They did the illusion for $1100. Super happy with the results!Do you mind me asking what your quote was to powdercoat?
I got a quote here WA and it was $1200-$1500 using the Illusion line powder.
Two part paints are completely different from "normal" enamel type paints like rustoleum.I'm located in the North end Tacoma. Going to get a few other quotes from some local area shops.
I talked with a friend of mine who used to work for PPG paint. He was recommending a 2 part epoxy paint. As durable if not more so, less expensive and easy to do touch up's if welding on brackets after the fact.
Considering going this route, similar to JSATX.
I'm sure the bras would help. Application would be a ***** though. And why cover it when you can just do it right the first time by not using cheap hardware store paint.Thanks BAR-AIR for that idea. Sounds like a pretty good deal for all that getting powder coated.
I think there's a wrought iron shop a block away from where I work that I'll have to check out.
I do really like JSATX's red on black. The photos don't seem to show the chipping. Is it chipping on the side chassis bars behind the front tires, as when you turn?
Wondering if a clear coating like the invisible car bra's would help protect those areas.
Please give an update on the soda gun when ya get it. I've been strongly considering getting one but only just now have an air compressor that can run one.Might be getting a bit carried away with the engine cleanup... note the pile of grime already on the floor, and that's just from simple green and scrubbing with a soft brush.
I learned about a process called soda blasting (media blasting with baking soda), which is great for engines because if any soda sneaks into the crevices, it dissolves in either water or oil and doesn't cause problems. I'm gonna pick up a cheap siphon blaster ($25) and a 50lb bag of soda ($40) from Harbor Freight today. I think between that and the mineral spirit blast, I should be able to get it looking nearly new before I paint.
Yeah, I'm just trying to find a decent cheap dryer that will work with higher pressure. Most of the cheap ones are 90psi max, and I'd rather not spend $60.Please give an update on the soda gun when ya get it. I've been strongly considering getting one but only just now have an air compressor that can run one.
You will need a lot of air. And very dry air so be sure and put a water separator in line.
Oh don't worry, I've got that bookmarked
I thought about it, but after some reading, the stock LNF clutch is almost identical to the GMPP, both of which are stronger than the stock LSJ. The donor had just over 100k IIRC, so I'll probably leave it for now for budget reasons. If it seems shot after driving, I may upgrade to an OTTP stage 2 or something.How many miles did your donor have? Might consider replacing that clutch while you got it out!
I've been impressed with the GMPP clutch it holds super hard.
Nuker-
Fair warning, it is a lot of work, but it is quite a feeling of accomplishment.Man, that turned out Looking Awesome! I'm gonna have to give this a try myself.
