You cover shipping both ways and I will send you my toe in boards and the digital level to do it yourself per DFs instructions.What vehicle does the alignment shop need to get the baseline for the goblin?
I might have to take you up on this offer in a couple monthsYou cover shipping both ways and I will send you my toe in boards and the digital level to do it yourself per DFs instructions.
I did mine and it tracks perfectly down the road.
This. I wasn't sure I could do it but ordered toe plates and a digial angle finder from Amazon. We did the initial alignment and took it on the road for the first time, took it back and realized it was way out. Made some adjustments as it wasn't to spec and thing is much better. Will be double-checking it again in a few weeks when I nut and bolt the suspension.I was a little hesitant to do my own at first. Then of course the realization hits that I assembled the dang thing, why not do it??!!.
No alignment shop out there will know your Goblin as well as you do. And besides, you already have all the proper sockets and wrenches.
I HIGHLY suggest everyone uses the above DIY links in Kyle's post and at least attempt to do the alignment themselves. Once you do it, you will not be nearly as intimidated. And the few odd tools you need are not very expensive - digital angle finder, good straight edge, two identical tape measures. And then, if you still question yourself, have a shop check your work.
