ncgoblin
Hey all,
I am adjusting caster and need assistance to get 8.5-9.0 degrees. The tools I am using are Longacre 52-78290 and toe plates. The steps I follow are:
1. 0 Gauge out on level surface.
2. Moved tire out to 15 degrees, set caster mode, leveled gauge and set to 0.
3. Moved tire in to 15 degrees, leveled gauge and read 8.0 degrees. As shown in the pic the gauge states negative this may not be a concern but I do know there is negative and postive caster so maybe someone can clear this up for me.
4. To get 8.0 degrees the upper ball joint has to be turned out more then seems right. The photo with the upper ball joint turned out just 2 turns is 4.4 degrees degrees.
5. The lower ball joint I turned all the way in if it was 4 turns out and the upper ball joint was in the current position it would only be 7 degrees.
All build logs I have scanned through show very slight adjustment to the default -4 turns out.
