ATMironov
I was able to spend about 9 hours on the car this weekend.
I spent forever getting the fuel pump and sender installed. I must have taken the pump in and out 10 different time as I couldn't get the pump to seal to the top of the tank. It turns out the adaptor plate I made was too big and was resting on the jamb nuts, not letting the gasket compress.
I finally got it all back together and and tank in the car. I reinstalled the intake and valve cover and mocked up the catch can placement. I now have the needed AN fitting on the way to make the lines.
After that I went to install the new CBM baffled oil pan
I diligently removed the old pan and dip stick and cleaned up all the old RTV (I didn't know these pans don't have gaskets)
I went to fit the new pan and its not even close to fitting. I should have measured before hand.
It looks like the the motor in the Goblin is sitting must closer to the subframe than in the Cobalt. On the passenger side the pan is hitting the subframe by at least 3". I looked as raising the motor, but then my intercooler set up doesn't work. I though about modifying the pan, but the pickup tube would need to be completely reworked. I think you could potentially make it work with a custom sub frame, but that's out of my fabrication skill set. So I decided to abandon ship and put the old pan back in.
Not all is lost, I still needed to add a 6AN fitting for my oil separator drain back line, so I took the opportunity to clean up the old pan, drill and tap a 3/8 NPT thread for a 3/8npt to 6AN fitting.
Looks like I didn't get a photo of it actually installed.... Oh well
