Well it’s all set for powder coating tomorrow!
Fingers crossed I didn’t miss anything.
I started to work on replacing the clutch and flywheel.
The donor only had 4,000 miles on it, but I wanted a lighter flywheel, so I figure I would change the clutch at the same time.
existing clutch. No dust to speak of
new flywheel
The alignment too doesn’t fit the crank. :-(. I’ll probably just wrap tape around it till it fits.
I went to change the throw out bearing and stripped the head of two of the T30 bolts. I started using extractors and both the heads came off the bolts allowing the bearing to come out.
i was able to spin one bolt out with vice grips, but ended up braking off an extractor in the 2nd bolt.
now I need to take the transmission to my other garage with the welder and try to weld on a nut to the broken bolt
I think this literally the last bolt I need to remove on this entire build, and it’s the only one I broke. :-(
And finally I worked on the wheel studs.
I’m having a hell of a time getting the right sized studs. But the front work, I need to order a different set for the rear.
