Thanks... then what gets connected to the port where you see a hose currently coming out of that is on the valve cover?The coolant port - under the tape? - goes to the coolant recovery tank small fitting near the fill cap. BTW, your main coolant hose going to the radiator looks like it is kinked, this will severely restrict coolant flow.
I mean.... what better way to cool your engine that run coolant directly into the valves?Definitely don't put coolant into the valve cover :O
Sorry I don't have the part number. I will have search my orders to see if I can find it. When you do put a filter on there, make sure to keep it clean and replace it often. It's a very bad thing if they get clogged and don't allow the crankcase pressure to vent. It may cause it to blow seals. The filter gets dirty on the inside so you can't look at it from the outside check it. I clean or replace mine every year.What kind of filter would I use for the crankcase?
I think most people use something like this: https://www.amazon.com/62-1160-Vent-Air-Filter-Breather/dp/B00029WXRC
Thanks! Might grab this, it'll add a nice look to the engine.Sorry I don't have the part number. I will have search my orders to see if I can find it. When you do put a filter on there, make sure to keep it clean and replace it often. It's a very bad thing if they get clogged and don't allow the crankcase pressure to vent. It may cause it to blow seals. The filter gets dirty on the inside so you can't look at it from the outside check it. I clean or replace mine every year.
