I ended up cutting them off the dash harness. I then taped them to the appropriate location on the harness and reconnected the wires.Hey Bill I need some help on the dash wiring harness. It’s around the Brake connectors. Video 9 at 3:49 Says to pull out the brake connector And save the wire. I don’t have a brake connector that looks like theirs. I have two connectors. One is gray that connects to the switch and it is labeled on a light blue wire for the Brake switch, Dash D4. The other is black with two wires and the purple wire is labeled Brake Pedal switch Dash - D3. I see what looks like these connectors on your finished harness. Which one is which?
I guess if there was ever a wire to get connected correctly, it would be the brake wire......Hey Bill I need some help on the dash wiring harness. It’s around the Brake connectors. Video 9 at 3:49 Says to pull out the brake connector And save the wire. I don’t have a brake connector that looks like theirs. I have two connectors. One is gray that connects to the switch and it is labeled on a light blue wire for the Brake switch, Dash D4. The other is black with two wires and the purple wire is labeled Brake Pedal switch Dash - D3. I see what looks like these connectors on your finished harness. Which one is which?
I did so, twice. My gap was right at .400 and I went with a .200 spacer.Did your run through the measurment procedure, zzp video.
Brad
