Brett
On todays episode of "Which hex key is it anyway?" we start a Goblin!
Had a few electrical gremlins to chase down and had to setup a relay for the Spal fan I put on the heat exchanger. Nothing major.
Also, had the replace the brake position switch since it thought the brakes were pressed all the time.
It has fluids but I need to get the car up to temperature and "burp" the coolant system then top it off.
Also, ran into some random tolerance stacking where my wheels just barley fit on the studs on the wheel adapter / spacers.
Up next, check every single bolt, alignment, have the Houston crew go over it, and test drive.
For various reasons, the test drive is going to wait till after the 25th.
Brett
Brett
