This is my first time working with a harness like this, so apologies if this question has an obvious answer.
Both of my harnesses have 2 different width lap belts. The adjuster of the 3-inch wide strap is huge and cannot pass through the opening in the side of the seat. The sewn-loop section from the strap's mounting point to the adjuster is long enough that the strap will not be tight unless the adjuster is in the seat, which I cannot see working with a person in the seat. I can't imagine the correct thing to do is have the adjuster being pulled tight against the outside of the seat. Did I get incorrect straps with my kit, or have I just not figured out how this gets mounted? I think everything would be fine if I had 2 sets of the 2-inch straps.
