Possibly but checking the items with evidence given. Plus the big main one, grounds. Isn’t it like 82% of electrical issues are grounds.My guess: data isn't flowing on the GM high speed LAN.
Still 120If all 4 items (OBDii port, power steering, BCM, PCM) are in the high speed LAN then you would be getting 60 ohms.
The 120 ohm resistors are suppose to be at the two ends of the high speed LAN wiring chain. Since the OBDii port isn't a computer, it doesn't count. So there are 3 computers in our goblin, power steering (has a 120 ohm resistor, and is at one end of the chain), the BCM doesn't have a resistor, so it goes in the middle of the chain, and a PCM, which has a resistor, and is the other end of the chain.
In your goblin, it is only measuring one 120 ohm resistor, so the high speed LAN isn't seeing both the EPS and the PCM.
If you disconnect the PCM, does it still measure 120 ohms?
That is power to EPS, it should plug in somewhere? If P/S is not powered I'd bet the high speed LAN is confused.I have 4 plugged in. Turn signal indicators on the dash light up when I engage the stalk. There is a blue plug with heavy gauge red and black wires on the EPS unit that is not plugged in but I assume that went to traction control? I put my ear close to the EPS unit and hear a relay click when I turn the key to ON
That is unusual but how are you jumping the starter?; jump 12V to the connection for the purple wire. The big battery wire to the starter should test 12V all the time. If there is not 12V there all the time we have other probs.Jumped the starter and it whirrs real loud but doesn't turn the engine over. Maybe bad starter?
