ah.b.normal
Been there, done that.There are two switches on the clutch pedal. Make sure they're adjusted right. If the top switch isn't closed, you get those exact symptoms. ( ask me how I know)
Those switches are on my list of things to check. The one at the end of the pedal travel is plugged in and the plunger depresses with the pedal. Seems unlikely that the switch went bad sitting in a box for the last couple months but certainly possible. Entirely possible that I messed up the wiring when I extended it but I followed the labelling and soldering pretty closely. I don't think that would explain the lack of voltage to the fuel pump though.There are two switches on the clutch pedal. Make sure they're adjusted right. If the top switch isn't closed, you get those exact symptoms. ( ask me how I know)
I too just found this issue in my harness as i was getting it in the car. You tied into the boost guage, have you had any issues? I had someone help me trace it back to the BCM grey connector on the back pin F3. I am going to try to trace it out and see if i accidently cut it during thinning.I think I've got this thing nearly firgured out. Thank you all for guiding me through this. I've somehow ended up with one wire that has no connection and I can't recall it being mentioned in the video. It is a grey wire that terminates in the gauge cluster connector. Anyone know what this should connect to?
I haven't touched the car in over a month. Got really fed up with it and decided we needed some time apart. I made a huge mistake trying to tackle this wiring harness myself. I don't have the patience for it and should have paid DF to do it.I too just found this issue in my harness as i was getting it in the car. You tied into the boost guage, have you had any issues? I had someone help me trace it back to the BCM grey connector on the back pin F3. I am going to try to trace it out and see if i accidently cut it during thinning.
Do you think thats an option? i just assumed they wouldnt be interested in trying to troubleshoot my harness.I had to do the same when I worked on my harness. I walked away for about a month. I was just to the point I forgot things, so when I went back, I had to double check where I was.
worse comes to worse, pull it out and send it to Df.
Is this issue still present? Have you pulled the OBDii codes?Update: I continue to be baffled by my wiring issues....
I'm still getting 118 ohms across the data wires at the OBDii.
I had a P2138 (similar to a P2128) Throttle Position/Pedal Correlation Issue that I couldn't track down for a long time. Tried new a new pedal, and new TB and a new jumper harness. Turned out it was the wiring that I ended up running a shielded wire. It's a common problem on the LSJ platform if you look in the Cobalt SS forums. It has happened to a couple here as well. I recommend that all LSJ's do this while the harness is on the table being worked as it's much easier then, but it got some pushback as not needed.Pulled the codes. Couple obvious EVAP codes and then there's p2128. Accelerator pedal position sensor 2 high voltage. Reading on some forums seems like that may mean a bad PCM?
That's a great idea. I'll work on that this evening. Heck, at this point I'd get it done as a tattoo if it would help lolDon’t do video. Mark it on a wiring diagram.
There's a tattoo you'll regret......when the next impossible problem hits you!That's a great idea. I'll work on that this evening. Heck, at this point I'd get it done as a tattoo if it would help lol
