Yesterday i finished installing new inner tire rods in my rack and pinion, i finished painting it, and installed it on the car. I also put new gasket on the oil pan
Correct, and shorter rod ends go in front, longer in the rearIf I remember correctly, the original front tie rods are moved to the rear and used on the toe link. The supplied tie rods should replace the front ones. One set is longer and one is shorter. I don't remember exactly whether it's the short ones that go up front or in the back.
Dre I too have this plug so you did not cut in step 12? Just verifying that I need to keep it seems that way based on your description.I found out it's my body harness plug.
Yes, Keep it. I used it when combining the harnesses.Dre I too have this plug so you did not cut in step 12? Just verifying that I need to keep it seems that way based on your description.
Thanks
No! You will go through the struggle like all of us. ha haCan we fix the clutch alignment issue before mine is built?
