jamesm
I didn’t use that flat piece in the left but I’d hold onto it until you have the brake installed and working. The rest looks good.So it looks like these are all the parking brake pieces I need?
It's as easy as remove and install if you do it now. Later, when (not if) it breaks it'll be a lot more involved. It took longer to find the right socket than removal and installation of the new part.Even with only 75K on the clock, would recommend replacing the timing chain guide bolt. The factory one will fail and replacement is cheap insurance for engine longevity.
Ecotec Timing Chain Guide Bolt
This aftermarket piece replaces the plagued stepped shoulder bolt that has a high tendency of breaking in the Ecotec 2.0, 2.2, 2.4 liter GM engine. It is far superior in every way and will not require you to replace the head that can be damaged when the factory bolt breaks. An absolute must have...zzperformance.com
It's simply removing the old one and installing the new one.
My kit didn't come with the parking brake cables. I bought replacements for the stock SS cables. Mine were rusty and one was seized.That cable should be connected to the handle directly. You don't need the longer cables that connect to the actual brakes as DF supplies new cables.
Sasqwatch, correct me if I'm wrong, but it looks like this is the same part on Amazon:Even with only 75K on the clock, would recommend replacing the timing chain guide bolt. The factory one will fail and replacement is cheap insurance for engine longevity.
or put a sticker over itBest to replace it BEFORE it breaks, since the stock bolt will break at some point.![]()
Do you have to pull the valve cover to make sure it seats properly, or just take one out and put the better one in?Yep, it's that easy. And yes the Dorman part is essentially the same part that ZZP sells. Best to replace it BEFORE it breaks, since the stock bolt will break at some point.![]()
So you only need the hand brake and primary cable? Do you need te secondary cables and the tubes? Or just the tubes?That cable should be connected to the handle directly. You don't need the longer cables that connect to the actual brakes as DF supplies new cables.
