Have no crank, no dash warning lights. Where do i start?
Oldchevyguy
I'm hoping that some of you that are good with diagnostics can help me.
With battery hooked up, and full voltage , I have horn , brake lights turn signals. There is power and the diagnostic connector.
Nothing happens except some relay clicking at the BCM, key on, and I do not hear fuel pump. No Crank either (clutched pushed in)
A flow chart would be great. Any ideas?
I would check for continuity of the tan twisted data wires.
They start at the OBDII connector and end at the ECM.
Make sure that tan with a black stripe at the OBDII is hooked to the tan with the black stripe at the ECM.
Do the same with the tan data wires with no stripe.
The data wires daisy chain through several modules and change colors twice.
Starts at the:
OBDII
tan and tan/black twisted
Power steering
tan and tan/black twisted - in
then brown and brown/black twisted - out
BCM
brown and brown/black twisted - in
then tan and tan/black twisted - out
If this were an automatic it would go to the engine harness and then back out to the ECM, manual transmissions don't do this.
ECM is always last
I would also check your grounds.
Oldchevyguy
Starts at the:
OBDII
Power steering
BCM
ECM is always last
Could I first check these wire continuities between aldl diagnostic connector and pcm? Or do they have to done separately?
Oldchevyguy
Ok. So I checked continuity with all the serial data wires. I expected a problem with the front to rear, or BCM to PCM ones. These are the ones that are lengthened. They were good. Next, BCM to power steering control unit. Brown and brown/white. BINGO! No continuity with brown/white. I repaired it with a new wire run outside the harness.
Now I have KO the security light (padlock). Pushed the unlock button on the fob, and now it goes away after a few seconds. BUT NOTHING ELSE ON THE DASH LIGHTS UP.. Also no crank no fuel pump running. ANY IDEAS??? BTW. I checked all the grounds.
baustin
Are all of the connectors on the bottom of the fuse block actually seated/tightened together? If you set the fuse block in place but didn't tighten the screws to pull the connectors together then I think you get that response.
Oldchevyguy
Thanks for the response. Sure there tight.
Oldchevyguy
Where did you run the repair data wires from and to.
Lonny, I replaced the brown/white wire between the power steering plug and the BCM plug C2. It tested open. All other serial data wires tested ok point to point as you suggested.
OptimizePrime
Check your BCM/ECM fuses.
Tighten down the ECM bolts really nice and tight.
Do you have 12v at the starter / ECM prong?
Did you paint your block where the starter mounts? It self grounds
Dominicnicklyn
not sure this would help but here is my no crank problem solved
https://dfkitcar.com/forum/index.php?threads/first-start-no-crank-help.1251/
Yes thank you, I've already come across your thread and we have the same symptoms. I have tried clamping the fuse box plugs down as tight as I can but it didn't change anything. The only difference between ours is that my donor had symptoms before the teardown.
I'm starting to wonder if the EPS module is bad and is effecting other modules on the bus.
