cdover2005
No luck on that ground, I called it quits for the day. Considering sending the ecm to zzp and having it tested, or buying a new one
Still has voltage with either or both plugs disconnected from the ecu. Buzzing stops with the crank relay outNext step will be to disconnect connector x2 from the ECM and see if you lose the voltage at pine 30 of the per/train relay.
