Last night I reworked the alignment again, up to about 9.9 degrees caster on both sides, and about -1.25 camber both sides. It's been raining like crazy here for the past few days, so I can't drive it yet. I'm hoping it might calm it down though. Not only does increased caster increase stability anyway, but doing so also rotates the tie rod bracket downward, which helps with the geometry of the Tie rods we've been talking about.
If it's still unstable, I think drilling new holes in the hub mounts is the last remedy (though I'm not looking forward to taking the whole front end apart) Relocating the steering rack doesn't work due to the heat exchanger location (unless that is also relocated). Longer shocks to increase ride height would work, but is an expensive solution.
To be specific, the car cruises pretty well at 70 mph on the highway. I can cruise 1 handed with no issues, and it drives mostly like a "normal" car. My issue is bumps, and especially bumps when under acceleration. I would say i've had the scariest situations at around 40 mph, under heavy throttle, on bumpy pavement. For my Boxster and Charger, the same stretch of pavement is no issue, it's a one handed affair with the skinny pedal on the floor. But in the goblin, just crossing a bridge (there's one just down the street) is a terrifying experience.
The rear toe link mount is installed correctly. And, for what it's worth, I don't feel the issue in the rear. It seems like a steering issue to me.
