A couple of things...
First, my tie rods are actually angled up just slightly toward the wheel. However, I'm unsure how to get them any lower.
Which leads to my next issue, my set up is not exactly as the factory setup is, as I have the tie rod mount in the upper hole in the front, and the lower hole in the rear. This is going to put the actual tie rod end link at the lowest position possible, unless I drill some additional holes.
The only thing I could do would be to swap the aluminum Mount brackets from left to right, since they are actually slightly tapered. That would put the tie rod a little lower, and therefore a little more level.
