I really like that side pod. You could always run on one on each side and connect them in series? If you have the dual pass setup then you could have each outlet go to a side pod and then have the two cooled streams connect back before gong back into the laminova cores. (opposite of the current dual pass setup).I'm really debating buying something like this to measure the IAT and IAT2 (since my ECU can't do both, I rewired 1 to 2). I'm curious how much its actually heating up the air. It could be that the air intake is just pulling warm air from the engine bay. I started building an air box for the intake for this purpose, but there's just not all that much room to make it happen. I think that's the route I'm going to go for now, because I don't think there's any benefit to adding a fan as it won't allow for any additional airflow, except at slow speed.
FYI, the Torque App will let you display IAT1 and IAT2 from the ECU. $5 paid version and then you input the PID, the free version can't do it.
I also considered making a box for the intake or a shield of some sort but I'm terrible at fab work. I was going to make it out of cardboard and then go from there.
