Shifter installed. Having issues with the tunnel cap flexing a ton due to cutting it in 3 spots
add a dead leg. World of difference.
Yup already thinking that waySince you have the extended version, you can stiffen the base plate with 2 bolts.
hand tight all the way inHow tight do you have this?
Have you tried backing it out?hand tight all the way in
Just tried it. It is also as if the cable at the transmission is binding and causing issues. I will test some more later. Im going to disconnect the transmission there. Also I need to add transmission fluid.Have you tried backing it out?
yup. Im going to start from scratch when I fix the flexing as I need to remove the plate etc. Will update then.do you have the bolt that goes through the reversers loose?
Post a picture of your cables and mount on the transmission. Are the ends of the cables angled coming off the bracket to the shift attach points? Any 'sharp' bends in the cable add a lot of friction to movement.Sooo i removed the whole shifter assembly and made sure everything was not stupid tight but tight. Loosening the connections at the reverses and it made it return a lil more but not what I expected.
The selector at the transmission is hard to move up and down. Remove the cable and it is super smooth and require little force to move. Seems like maybe the cable?
Remove the tunnel piece and added screws on the sides to stop flexing. Reinstalled the cap with rivnuts and the flexing is gone.
Installed seats and dash panel as well
View attachment 22888View attachment 22889
I had those son order with DF and they get getting pushed back on back order so I had to go a different routeThose are some mighty fine seats.![]()
I had mine on order about a month after I ordered the kit and had to wait 2 months from caridI had those son order with DF and they get getting pushed back on back order so I had to go a different route
