I know this diagram was mode for Cobalt/Ion, but I’ve been curious if the IC pump should be powerful enough on the Goblin for the front mount h/r and a second one above the engine. This was my plan with my LSJ car, and if I go LSJ-t I’d stick with air to water, using an intercooler similar to what DF sends for LNF cars. Just worried the pump wouldn’t be powerful enough for that.
so you’re still running the LSJ intake? I was planning to ditch that if I went LSJt. What turbo you run?I run the normal SC kit IC circuit on my LSJ-T and I have no problems with IAT. I do have the dual endplate and Option B tank, but I am running everything as it comes in the DF kit.
edit: I also use just the ducts and no fan on the heat exchanger.
Do you know where about your IAT2 temps are at? I’m thinking of doing LSJ T eventually and using the intake manifold still if possible. I’m currently working on cooling mods at the moment to keep this blower cool for track daysMy donor had the entry-level turbo swap from ZZP, so LSJ intake and K04 turbo.
Meaning your current setup is different from the diagram above? I’m currently following the diagram (minus the second heat exchanger) and hoping I’m getting it right loli think I changed mine to help keep the pump cool. can’t tell you if it helps or not. Don’t see why either way would be better or worse as far as overall function
pump out to dual pass end plate in
plate out(s) to Y
Y to heat exchanger
HE to pump.
I ran mine very similarly for the same reason (trying to keep the pump cooler):i think I changed mine to help keep the pump cool. can’t tell you if it helps or not. Don’t see why either way would be better or worse as far as overall function
plate out(s) to Y
Y to heat exchanger
HE to pump.
I'm going to piggyback with you, since I have a similar, but different problem. My IC pump doesn't run either. I checked the plug and got no voltage. Checked the 15A fuse and its not blown, but I don't have voltage on either side of the fuse either. Suggestions on what to check next?I'm going to piggy back on this thread...I discovered yesterday that the fuse for my intercooler pump (stock replacement when I built the Goblin, from J Reiland on Ebay) was blown. I replaced it, and it immediately also blew. I double checked the plug, and the polarity is not reversed, I got sustained 12V, so I doubt the problem is in the wiring. Next step will be to pull the motor and bench test, but before I pull it (and drain all the coolant), figured I'd see if anyone else has hit this issue or if you can think of any other solution. Seems to me like the pump motor is bad...
