I'm going to piggy back on this thread...I discovered yesterday that the fuse for my intercooler pump (stock replacement when I built the Goblin, from J Reiland on Ebay) was blown. I replaced it, and it immediately also blew. I double checked the plug, and the polarity is not reversed, I got sustained 12V, so I doubt the problem is in the wiring. Next step will be to pull the motor and bench test, but before I pull it (and drain all the coolant), figured I'd see if anyone else has hit this issue or if you can think of any other solution. Seems to me like the pump motor is bad...
