Does the shifter cable hardware come with stage 2?Manual shifter installation and adjustment
Step one Install your tunnel cover. Step two Install your shifter cable bracket Step three Identify one of the cables on both ends with a sharpie mark or piece of tape. Route your two shifter cables along the tunnel and through the opening in the firewall. The cables need to be positioned...dfkitcar.com
Your transmission cable mount will be different.
Do you have any pictures on how much counterweight you trimmed?View attachment 24854
you will need to trim the counterweight as noted. Also the mount on the top of the bracket needs to pushed out a little as I had binding there. I put the bracket in between the rubber bushings and it helped out a little.
Is this how everyones looks? I feel like there is some tension on my cables with it being so cocked.View attachment 24854
I have F23 as well but yea mine look similar, Ive seen a few other people show that the mounting plate was updated in 2021 from a side by side, to a more up and down mount for the cables to allow them to lay better. I have kit #360 and I wonder if I was before they included the new mount.I have an F35 trans and those photos are the F23 (I think). But yeah, one of my cables has a decent ‘bend’ in it and works perfectly fine.
