Well, it's been a while since I documented my progress. Been putting in an hour here an an hour there over the past few weeks. Didn't get as much done over the holiday break, but got a lot done last week.
Got the steering, pedal box, brake booster and brake lines installed. That all went pretty smoothly. Put on new inner and outer tie rods since the donor's were so rusted, I had to cut them off the Cobalt.
Few days later, worked on getting the radiator installed an plumbed in. Also got the fuel take mounted up. I realized, as I was putting in the fuel pump, that I was missing the retaining ring that goes on the top to hold the pump in place. A quick email to DF and one will be on the way soon.
(Yes, that's a wagon full leaves that my kids refuse to get rid of. They'll replace it with fresh dead leaves next fall too.)
I'm usually doing this on my own, but I had some help one day! He's a good supervisor.
I got a surprising email on Monday that my wire harness was done and was on it's way back home. They must have worked on them over the holiday break. They only had it about a month. I wasn't really expecting it until mid February. They did a great job! Much better that I would have done. It was cut down from 22lbs to 12lbs. When installing the pedal box, I couldn't find my brake and clutch switches. I looked everywhere, but no luck so I bought new ones. Got the harness back, and boom, there were still connected to the harness. Must have forgotten to take them off before sending the harness to DF.
I was pretty eager to get the harness in. Got it just about done, just some wire ties to tighten up and connections to plug in.
In preparing to mount the transmission back onto the engine, I read that the shift counter weight on the F23 transmission hits the frame in certain gears. Figured I'd trim it up a little bit before it's mounted.
Also had to order a new clutch line that connects to the throw out bearing. The bleeder and line connection was completely rusted and wasn't going to work. Hopefully have that here in a few days.
