25074
Ok…let me try to explain
my donor is an 06 2.4 SS. Non SC or TC.
I thinned my own harness. I have everything ready to start the car so I am done with stage 1 stuff.
when I turn the key, the butterfly activates but no crank and the dash lights up
I have power to everything so it’s not a ground issue.
I have power to the relay that activates the starter but the Starter will not turn.
my test light shows power coming out of the output side of the relay terminal in the fuse box and it would stay lit once you let go of the key (I assume this is the cars way of continuing to crank to start the car and would stop once it was running)
I can jump the purple wire from the battery and the starter cranks.
I tested the relay with a 12v power supply and it clicks.
if I jump the terminals where the relays sits in tjethe starter cranks.
I have continuity from the relay terminals down to the purple wire at the Starter.
I think it’s an anti theft issue, but the light is NOT activated on the dash.
the car ran fine when I striped it.
I have continuity between the data wires at the OBD
PLEASE HELP ME!!!
PLEASE HELP ME!!!
