viperbmw69
I am having an odd issue. Sometimes when I try to start the Goblin I get Nothing from the key turning. No Power No Dash nothing. Then if I unscrew the X3 plug on the BCM it will start normally...... Its odd and it doesn't seem to be an issue with Anti-theft. Has anyone had issues like this? I did cut the IGN wire on X3 in BCM by mistake and had to rewire it. Although I checked the solder multiple times and checks good every time when I move it around.
Sometimes I can get the car to get power with Unpluging the Anti-theft switch on the Key Housing. as well as the Green plug on it. This does not always work.
2008 LS 2.2 Manual F23
